Tractor Talk Discussion Forum
Briggs Stratton Model 5 S
Irving Legate
10-10-2005 06:19:00
Need to know how to remove a broken leather points opening plunger from the recess in the back plate...approx. 1/4 of the plunger broke off in the recess...have tried a drill bit and dental pick to remove remaining portion and no luck. Any Suggestions? Is the removal of the whole back plate the only solution? I have loosened the 4 mounting bolts of the back plate, but the back plate will not come loose. What else could be holding the back plate? Is it possible a previous owner used gasket sealer to mount the back plate? Gentle prying of the back plate w/ bar did not loosen it. How much force will the back plate take without breaking the cast aluminum back plate?
MN Bob
10-11-2005 06:06:42
 Re: Briggs Stratton Model 5 S in reply to Irving Legate, 10-10-2005 06:19:00
He probably could not get the address to take, if this on dont try a google search for Briggs 5 S and you will see many sites/post. Some of them refer to disassembly/restoration
http://www.smokstak.com/forum/showthread.php?t=20445
UncleTom
10-10-2005 17:20:42
Will this help?
Irving Legate
10-10-2005 18:12:37
 Re: Briggs Stratton Model 5 S in reply to UncleTom, 10-10-2005 17:20:42
I appreciate your f/u..however all I have receive is "will this help?"...no attachment..no comment...and no link...
I am curious to what you have to share.
Please try to re-submit.
Thank you.
