Tractor Talk Discussion Forum
Massey Harris 101 Junior/continental F140 no power
101JRWebberville
10-10-2005 19:38:49
I recently purchased a 1941 101 Junior with a continental F140. The tractor is having some issues running. Any time the tractor is under any strain it stalls. Stain meaning going up a slight hill, or having more then 2 people sit on the tractor. This was running in 3rd gear. If you go into any other gear it stalls right away. The tractor is still a 6 volt system, the generator is not hooked up and it has a 12 volt battery installed. Oil pressure is at 35 (I believe) can check this tonight if needed. My father suggested that the issue was the distributor is not advancing since there is a 12 volt battery installed. This is our first tractor and don’t know much about them. Does anyone else agree this may be the issue, or is there something else I should be looking into? Possibly a bad governor?
Also I am looking to convert to a 12 volt system and also would like to get rid of the points. I would like to get a kit to do this because they usually come with a bracket for the alternator, I don’t feel confident I could make one that would work well. Does anyone know of a good kit?
farmered
10-11-2005 06:23:32
 Re: Massey Harris 101 Junior/continental F140 no p in reply to 101JRWebberville, 10-10-2005 19:38:49
That is a safety feature they had way back then. They just didn't run with more passengers than seats.
In all seriousness, better get it running right with the 6 volt system it came with before spending a lot on high tech "improvements" after all, the 101 Junior is not a race car. There are so many things or combinations of things that could be wrong that you should have someone who knows engines tune it up for you.
It's pointless (pun intended) to spend a lot on kits when the engine may have some basic problem. Advance is mechanical so 12 v. will make no difference.
RN
10-10-2005 21:10:41
Distributor doesn't sound like problem- you say you are only moving a bit in 3rd gear, check your transmission and brakes. 12 volt battery on 6 volt system would not be good for continous use- coil and condensor heating is problem, points will wear bad when condensor goes. Do you have idle but dies trying to move with more throrrle?- check for fouled carb, this is a indication of clogged main jet passage. Check Massey forum archives. What is past history of tractor use? Has oil been changed in transmission/rear end? engine? point gap checked? Plugs and wires? Check carb, governor , trans. Oil pressure seems good, the stalling in other gears than 3rd seems to indicate something in transmission. IHC /AC known to get into 2 gears at once, stall. General lack of power from stuck rings, bad valves would not be transmission gear specific. Get more info. RN
