Tractor Talk Discussion Forum
Hey Allan NE
Dug
10-10-2005 21:29:45
Sorry to hear about your wife, hope all turns out well...
Got a question about my F 11, one of the hydraulic cylinders started leaking, needs a new set of seals. Any recommendations on rectifying the situation? Should I dismount the entire cylinder and take it to a shop or is it a DIY job? Is that sucker as heavy as it looks???
Dug
Allan in NE
10-11-2005 06:23:31
 Re: Hey Allan NE in reply to Dug, 10-10-2005 21:29:45
Mornin" Dug,
The F-10 has about the easiest cylinders there are for resealing; on the other hand, that F-11 is kind of a stinker because they work in both directions.
However, it is a straight-ahead job, but you just have to keep your wits about you (thinking of oil flow)when you put it back together, as they have changed the design of the seal kit somewhat.
If you are the mechanical sort, you can easily handle it; if not, haul it into a shop and they can swap "em out in a couple of hours for you.
Also, if you are lucky enough to have the dead-head end of the cylinder mounted in the rear frame upright, you can disassemble it on the loader and leave that tube right where it is, just pulling the ram out the forward end.
The early loaders mounted with the ram pushing backwards towards the tractor axle tho and in this case, the cylinder has to either be completely removed for repair or you have to drop it down where you can pull it out under the back of the tractor.
Hope this helps,
Allan
Dug
10-11-2005 17:44:14
 Re: Hey Allan NE in reply to Allan in NE, 10-11-2005 06:23:31
Thanks for the reply, Allan. I was down at the barn looking the situation over tonight and with your suggestions, I think I can handle the job...seems like I've said that before...and lived to regret it! :- )
I'll keep your wife in my prayers until she is home again!
Dug
Keith-OR
10-11-2005 07:00:17
Allen is the F10 loader the one you have...Need to find pic. of one. Keeping your Wife in our prayers, Hope she gets better soon and home so she can get you back in line...God bless Keith
Allan in NE
10-11-2005 07:23:55
 Re: Hey Allan NE in reply to Keith-OR, 10-11-2005 07:00:17
Hi Keith,
No, I have the smaller F-11.
First picture is of a F-10 mounted on a 656, second picture is of my little F-11 on the H. I"m crazy "bout this combination, but it sure isn"t the horse that those old F-10s are.
Thanks,
Allan
third party image
third party image
Keith-OR
10-11-2005 14:41:55
 Re: Hey Allan NE in reply to Allan in NE, 10-11-2005 07:23:55
Thanks for the pictures Allan. Keep us posted on wife's progress as all of us on the forum worry and are thinking, and praying for a speed recovery....God Bless...Keith
POLK cRAWLER
10-12-2005 08:10:39
 THIS ONE FOR KEITH IN OR in reply to Keith-OR, 10-11-2005 14:41:55
Keith:
Think I have asked this before but memory gets shorter?. I am in Polk Co E of Salem.
Join you in best wishes and prayers for Allan and his wife.. maybe a line or two for the hors.e
PC
