Tractor Talk Discussion Forum
Pull Behind Bushhog for a 1950 Farmall Cub
Doris Kelly
10-16-2005 22:08:28
Ok I know nothing about these tractors but my father in law wanted me to see if I could find a pull behind bushhog for a 1950 Farmall Cub tractor. Could someone please help me find one i would really appreciate it.
Thanks
Doris
Dan England
10-18-2005 01:42:30
 Re: Pull Behind Bushhog for a 1950 Farmall Cub in reply to Doris Kelly, 10-16-2005 22:08:28
Lost Posts???? Early yesterday I posted a response about a Cub with a PTO driven, pull-behind bushhog type mower which I had seen in Stamps, Arkansas. Later in the day I noticed that my post was missing and wondered how and why it disappeared. I noticed last night that it was present but it is missing again this morning. I am not upset about its loss, the info it contained is of no particular value to anyone, just a comment that I had seen a pull behind mower on a Cub. I am curious though about how it was present initially, then lost, then re-appeared, and now is missing again. Any ideas on why this is happening? Dan
Kevin (FL)
10-17-2005 09:35:20
Doris,
We have what I believe is a factory-built "bushog" for the Cub, but at this time it's hidden by tree limbs from the hurricane. As soon as I can get pictures, I'll post them. This mower trails behind the Cub and is driven by the PTO. It has a belt on it with two pulleys--one at 90 degrees to the other. It's small enough (maybe about 3' max) for the Cub to handle it, but I wouldn't want to go into a field with a bunch of debris or small saplings. For grass mowing it should work as well as the typical IHC or Woods belly mower. Besides this one I've only seen one or two others, but I'm sure they can be purchased used.
Tim Shultz
10-17-2005 05:41:48
I don't know about the pull type mowers(becouse I have never owned a cub) but a freind of mine has a belly mower for two of his cubs.
sorry thats all I can tell you.
Tim Shultz
bj/8n/mt
10-17-2005 05:11:43
Only way I know of to do it is with a self powered unit. A couple of people make these for use behind ATV's. The link below is to one source.
Kind of spendy but it will do what you propose
Your mileage may vary
Bus Driver
10-17-2005 04:43:37
Some will take exception to this idea, but the Cub has far too little engine horsepower for "bush hogging". I should know, I own 4 of them. I seriously doubt that a cutter set up for the Cub PTO situation will be found.
evielboweviel
10-17-2005 03:05:23
1 pto turns at engine speed 1600rpm on a 1950
2 pto turns same directiuon as engine which means it is backwards to all standard pto's
NOW the option that I am aware of is to have/get a fasthitch on the tractor and then can get a 42" fasthitch rear mount bushhog or a 59" finish mower. Both hard to come by and not cheap, however doable if enough money is avaible.
OR even rarer is to get a HUB CITY pto reverser/speed reducer, no longer made. Install this and the hitch up a 4' pull type bushhog
Just takes money, money and lots of looking.
Good luck
Ron
Pete - IN
10-17-2005 01:23:46
Keep in mind that not any bush hog will work with a Cub. The PTO turns in the opposite direction of a normal tractor.
