Tractor Talk Discussion Forum
replacing a steering wheel
JerrySchill
10-17-2005 06:14:58
I"m replacing a steering wheel on a Farmall H. While I got the nut off OK, I"m having a bear of a time with getting the key out. Before I reinvent the wheel, (no pun intended) can anyone offer any pointers?
RustyFarmall
10-17-2005 06:40:46
 Re: replacing a steering wheel in reply to JerrySchill, 10-17-2005 06:14:58
The key is easily removed after the wheel is off. Removing the wheel is the tough part, have you tried a gear puller? Sometimes the gear puller won't do the trick either. Then it is time to fire up the torch and heat the hub of the steering wheel to a nice cherry red, then you can remove it with your hands.
Mike M
10-17-2005 06:34:29
Have you pulled the wheel off yet ? Just to change wheels you shouldn't need to remove or replace the key but it is a good practice to do so.
