Tractor Talk Discussion Forum
seized engines
amymarchwicz
10-19-2005 12:17:54
I have a tractor that I ran low on oil is it possible to unseize it. If so how with out taking it appart
MarkB_MI
10-20-2005 03:51:43
 Re: seized engines in reply to amymarchwicz , 10-19-2005 12:17:54
To add to the other comments, if you tear the engine down now, you have a chance of salvaging many of the parts. On the other hand, if you are able to get it unstuck (unlikely), you will only do more damage. Chances are one or more bearings have "spun", which means they can't get any oil. Also, you'll probably do more damage to the cylinder walls due to broken rings, etc.
buickanddeere
10-19-2005 20:16:15
Disassemble every engine part and inspect each component for wear, over heating and bending/warping.\
Sorry but that engine is junk until a pile of money is poured into it. You might get it broke loose and run for a little while but it's going to go bang & crunch.
wayne2
10-19-2005 22:10:14
 Re: seized engines in reply to buickanddeere, 10-19-2005 20:16:15
True,very true!!
Jim_bobb
10-19-2005 17:54:15
How about findinmg a tractor that has a failure such as a transmission & one can salvage the existing engine for low cost.
wayne2
10-19-2005 15:35:43
Sorry Darling,be sure to put wedges under front of tractor when splitting, block every thing so it dosn't rock. use floor jack to slide pieces apart, If you get that far and arn't married give me a call. LOL Wayne
dhermesc
10-19-2005 15:01:27
There is a chance that it might free up once its cooled down. Put the tractor is road gear and rock it a little. Beyond that there's too many things that can be causing it to be froze.
Even if you're lucky and it frees up, the engine is mostly toast. Low or no oil destroys every contact surface in the engine and subjects the rest to temptures that warp everything out of shape.
Wi Craig
10-19-2005 14:11:14
Bad news, NO.
old
10-19-2005 12:27:02
Most of the time if you run them low on oil and it locked up on you then there is no hope to fix it unless you rebuild it. The rings will be shoot, and the bearings etc will also be.
