Tractor Talk Discussion Forum
IHC TD 15 Series B Crawler
John L. Stanbar
10-20-2005 18:59:58
Our old engine club ( Northern Michigan Antique Flywheelers ) have a IHC TD 15 crawler. We need some info on this tractor. What weight and type of oil is used in the transmission? Is the flywheel houseing supposed to be wet or dry?
Thank you to any and all that can us the answers to these questions.
John
BobMo
10-21-2005 06:20:51
 Re: IHC TD 15 Series B Crawler in reply to John L. Stanbarger, 10-20-2005 18:59:58
I wonder who's right! The manual will answer the questions and is normally the 1st place you would look before tackling one of these units. You'll also find that a lot of the time these questions are better addressed in the "Crawler" forum.
bigdiesel
10-21-2005 03:51:52
the TH15B is a power shift machine. The transmission uses IH Hy-Trans oil. The bellhousing is wet, as it uses a torque convertor. check the starter, it should have a gasket where the 3 bolts go to the bellhousing to stop leaks. don't put 90wt in the transmission, you will really mess it up. Tractor weighs 15 ton without blade.
hector gemme
10-21-2005 02:33:27
HI The oil need 80==90 and the housing fleywell is dry and the weight should be 32000lbs.HECTOR
JD790
10-20-2005 19:16:13
You can buy Manuals from this website
