Tractor Talk Discussion Forum
Still not sure-MH engine
DCM
10-21-2005 06:07:06
Would anyone know or have any experience with mounting an engine from a '50 Dodge (6 cyl) into a Maseey Harris 44 frame. Are mountings the same and can this work.Thanks,Dan in AB
Jeff Oliver
10-21-2005 16:32:28
 Re: Still not sure-MH engine in reply to DCM, 10-21-2005 06:07:06
Not sure howmuch trouble it is but it definatly can be done. Local puller has one around here.6 cylinder Dodge in a 44. If I can get ahold of him I'll see what he says about it.
DCM
10-21-2005 21:04:22
 Re: Still not sure-MH engine in reply to Jeff Oliver, 10-21-2005 16:32:28
I would be interested in knowing more Jeff, Thanks.
J. Schwiebert
10-21-2005 16:01:56
The early 101 M-H tractors used the Chrysler 6 cylinder. You might wantto look at a 101 frame and see if it will bolt to the rear end. What is the matter with the H model Continental/
DCM
10-21-2005 21:07:32
 Re: Still not sure-MH engine in reply to J. Schwiebert, 10-21-2005 16:01:56
Have an engine,no car. Got a 44, no block. So I"m thinking 1+1=1, Dan
Bob M
10-21-2005 07:38:18
Dan - I doubt the mountings are the same. The MH 44-6 used a Continental flathead six (F-226) It's a completely different engine from the Chrysler flathead six. And I don't know if the Continental 6 has the same mounting as the "normal" MH OHV 4 cylinder in the 44.
OTOH it probably would not be too difficult to adapt the Chrysler engine. And it would make for a unique and smooth-running 44!
DCM
10-21-2005 21:10:04
 Re: Still not sure-MH engine in reply to Bob M, 10-21-2005 07:38:18
Howdy Bob, just tossing around the idea.Would be worth it if it worked.Dan
