Tractor Talk Discussion Forum
Murray tractor info????? snowblower attachment????
Randy Albert
10-24-2005 11:51:23
I was given a murray garden tractor model 46370x14 witch I have no info on . I also was given a murray snowblower attachment # 24577a .I have tried to link the two but they are not compatable and I have now way of knowing what snowblower is compatable with the tractor . or what tractor is compatable with the snowblower. Any info would be greatly appreciated thanks Randy
JoeK
10-24-2005 18:38:37
 Re: Murray tractor info????? snowblower attachment in reply to Randy Albert, 10-24-2005 11:51:23
Many of the "older" garden tractor blowers had a separate"drive unit" that mounted to the tractor before mounting the blower.Usually this consists of a metal frame containing 2-3 pulleys and a linkage that mounts beneath the tractor under and behind the front axle.Ofttimes this unit gets left behind,hanging on the wall with the tire chains when the main unit and tractor leave home.A lot of the older blowers were made for the tractor mfgs by Haban(now defunct) and blower units themselves would fit several makes and models,WITH the correct drive unit for that tractor.
dave from MN
10-24-2005 17:23:31
If it is belt driven and you have some metal, a way to cut it and drill it, and if needed a welder, you should be able to mount it if it is not a factory /aftermarket fit.
Allan in NE
10-24-2005 14:38:41
Randy,
Does it look anything like this Murray setup?
Allan
third party image
randy albert
10-24-2005 19:19:05
 Re: Murray tractor info????? snowblower attachment in reply to Allan in NE, 10-24-2005 14:38:41
no allan it doesn"t look anything like it thanks for trying . how well does this unit work for you thanks again randy
MN Bob
10-24-2005 13:56:52
Try the Garden tractor site under related sites. Will probably have some luck there.
