Tractor Talk Discussion Forum
Cockshut/Coop 40
Chester Rougeot
10-24-2005 17:18:42
I have a Cockshut/Coop 40. It did not have a battery or cable on it when I got the tractor. I need to know if it is a neg or pos ground before I try to start it.
Leroy
10-25-2005 17:11:46
 Re: Cockshut/Coop 40 in reply to Chester Rougeot, 10-24-2005 17:18:42
Just talked to my friend that has multiple 20's, 30's, 40's, 50's, 540, 550, 560, 570 and he said all tractors up untill the Golden Egal were 6 voly positive ground, the Golden Egal was the first 12 volt
Dave Sherburne,NY
10-25-2005 15:51:50
Ask on the Oliver Cockshutt board below,
Phil Heisey would know and also, let them know if it is gas or deisel. I think that makes a difference
I've got one in the shop in pieces its a diesel
and I think it takes two batteries. I got it in pieces kinda like a kit.
Leroy
10-24-2005 17:34:50
Check for if 6 or 12 volt first, alternator 12 volt negative, Generator either 6 or 12 volts, probably pos ground, but not sure
MikeinKy
10-24-2005 19:19:58
 Re: Cockshut/Coop 40 in reply to Leroy , 10-24-2005 17:34:50
If it has a battery ignition, whichever post on the coil,pos or neg, goes to the distributer is the polarity.
