Tractor Talk Discussion Forum
O/T '97 Dodge 360
KPL
10-24-2005 17:38:44
I have a 1997 Dodge pickup with a 360 in it. The check engine light come on a while back and I would like to take care of the problem. I didn't want to spend time and money on the dealer mechanic, so I bought a OBD2 code reader. It worked fine and the code says "system to lean (bank 1)" Could someone tell me how to fix this? I work on vehicals and tractors all the time so I am not afraid to work on it, just need some advice. Thanks KPL
Bryan In Iowa
10-25-2005 06:07:10
 Re: O/T '97 Dodge 360 in reply to KPL, 10-24-2005 17:38:44
Remember "Cause and Effect !" Just because a code is set , it dosen't always mean that component is bad. O2 sensor codes can be caused by any number of things . Fuel pressure , plugged or dirty fuel rails, injectors , vac leaks, etc. I get tons of customers in my shop that have been to "The Zone " for free diagnoisis< codes read , parts bought , throwed at it in atempt to fix it > . By the time they come here, pay for a REAL diagnoisis , and get the problem solved , they could have saved a lot of $$ and headaches. I recommend biting the bullet, taking it in to a repuatable shop , and at least getting it diagnoised .
Darin in Nebraska
10-25-2005 07:27:47
 Re: O/T '97 Dodge 360 in reply to Bryan In Iowa , 10-25-2005 06:07:10
You have to remember guys and gals, this is coming from a guy that owns a shop. You would be surprised how many cars are fixed properly in "The Zone".
bradk
10-25-2005 05:36:44
Before throwing money blindly,you need to see what that sensor is doing in comparison to bank 2.Also what fuel integrator/block learn is at.Those code readers are OK,but useless as far as diagnosing.Something as simple as a vacuum leak could be causing your problem.I would take it to a smaller reputable shop & have them check it.~brad
Leland
10-24-2005 21:02:18
Sad thing is that those O2 sensers only start a 100.00 and go up wifes car needs a couple .
jfp
10-24-2005 18:04:06
I don't know much about late model dodge but does it have oxygen sensors on both exhaust manifolds??
KPL
10-24-2005 18:21:16
 Re: O/T '97 Dodge 360 in reply to jfp, 10-24-2005 18:04:06
When I looked I couldn't see any sensors on either manifold. But I could be wrong.
jfp
10-24-2005 19:14:55
 Re: O/T '97 Dodge 360 in reply to KPL, 10-24-2005 18:21:16
I should have said lower exhaust. If this is the problem, unplug it and see if reads the same on the computer. If there is no change then that is not the problem. When I check things like that, I usually unplug stuff until the computer reads the same problem. Any problem that is different would mean that componet is working correctly. Good luck.
John in Nebraska
10-24-2005 19:13:35
the exhaust 0-2 sensors are on the lead down pipes, then another set behind the catalytic converter, am thinking the 0-2 sensor for bank-1 is incorrect, or is telling that side to cut back on the fuel. have you cancelled the code? and tried driving it some more, to see if it returns? john in Nebraska
wayne2
10-24-2005 19:34:29
 Re: O/T '97 Dodge 360 in reply to John in Nebraska, 10-24-2005 19:13:35
Sweet Hesus, you Guys are great,from a guy who drove Model A Ford to high school, this new fangled stuff is way over my head. Glad To know someone out there to BANK ON!!!! Wayne
KPL
10-24-2005 20:50:47
 Re: O/T '97 Dodge 360 in reply to wayne2, 10-24-2005 19:34:29
Thanks for the help guys. I will have a look see at those sensors and see what I can find out. Thanks for the advice.
KPL
