Tractor Talk Discussion Forum
still farmall cub carb problems help??
t.r.y.
10-28-2005 05:29:20
I tried the few things you guys have suggested plus. Its the universal senith cub carb new. I cleaned it and reset float when hot it starts easy and runs great after adjustment but when cold it won't start. floats can't go any richer. maybe bigger jet ????? choke don't do anything but change engine runnning sound when choke on running. Normally these things should flood quick right? seems to me needs more full. help?? thanks guys
Hermit
10-28-2005 09:32:51
 Re: still farmall cub carb problems help?? in reply to t.r.y., 10-28-2005 05:29:20
If it runs great hot and the choke has no effect and won't start cold, it's sounds like a vacuum leak. Maybe between the carb and manifold or manifold and head or possibly a cracked intake manifold where the crack opens wider when cold.
Chuck430C
10-28-2005 07:40:02
I have a Cub Manual for sale on the YT photo ads that will take you through it and find the problem.
Coloken
10-28-2005 06:36:39
Any choke should kill the engine or come close to it. If choke can't flood the engine; the choke is not sealing or you have air leak around it. Or, the hole of the float valve is too small, or the float valve doesn't drop far enough to open it up all the way. Does it get enough gas to run at full power, like uphill? If not,look for restriction in gas flow.
Kennyp
t.r.y.
10-28-2005 05:34:07
Do you know what the float adjustment should be ?? maybe I can try a bigger jet do they have numbers on. ????? ??
Coloken
10-28-2005 06:39:57
 Re: still farmall cub carb problems help?? in reply to t.r.y., 10-28-2005 05:34:07
If it "runs great" would indicat that the jet is correct. Something is stoping it from "gulping in" larger quantuties when you choke.
