Tractor Talk Discussion Forum
3910 ford loader
ford fixer
10-28-2005 15:00:55
will a 772 Ford loader fit a 3910 ford?
RodinNS
10-28-2005 15:13:41
 Re: 3910 ford loader in reply to ford fixer, 10-28-2005 15:00:55
Probably. The 772 was the loader prescribed for the 3600. I think the newer version, the 776 was generally used on the 3910. They were much the same tractor. So, provided the correct mounting hardware is supplied, you can most likely mount the loader. However, the odds of having the correct mounts are probably not so good. Torch and welder, along with some ingenuity should make it fit fairly easily. HTH.
Rod
