Tractor Talk Discussion Forum
Case VAI Identification
Glen Redmon
10-29-2005 05:35:09
I am trying to identify a tractor with 3 numbers missing from the serial #. I have found the "VAI" was mfg from 1942 to 1955. My Case # is "VAI 6001". Engine serial #73-G04969. I don't know why the full 7 digit # was not stamped, perhaps someone could help identify the year and the reason all numbers weren't stamped.
Glen Redmon
11-01-2005 04:40:14
 Re: Case VAI Identification in reply to Glen Redmon, 10-29-2005 05:35:09
I found another # on the hydraulic bucket set up. I appears to be factory Case with the following, "Case WM3 661". This tag appears to be machine stamped and is riveted to the lower hydraulic tube on the right side. I appreciate you Walter, thanks.
WALTER T.
10-31-2005 18:28:55
WELL I WOULD SAY YOU HAVE ONE OF THE FRIST 1946 VAI CASE TRACTOR'S OUT THE DOOR FOR 1946. AND THE ENGINE SERIAL NUMBER MATCH'S THE FRIST MODEL'S FOR 1946
