Tractor Talk Discussion Forum
756 3 pt floats down--revisited
lenray
10-29-2005 16:34:17
Thanks fellas for the help--need more help. It is the quadrant lever that is lowering as you said.
Looking at it there is a spring and two round nuts that are threaded up against the spring. These round nuts have small holes in them--is that to put a punch in or is it a roll pin can't seem to move those nuts.
Any help here would be appreciated.
Thanks len in michigan
Allan in NE
10-30-2005 01:21:12
 Re: 756 3 pt floats down--revisited in reply to lenray, 10-29-2005 16:34:17
Hi Len,
You are trying to adjust the tension on the lever at the wrong place.
There is a friction clutch for the draft lever as well as the position control lever. Tighten the one on the outside just a bit and that lever will stay where you put it.
Allan
third party image
IaGary
10-29-2005 19:18:49
I don't know what type of fiction setup the 756 had but I think you would receive better response under the Farmall Forum.
