Tractor Talk Discussion Forum
wiring diagram
having problems
10-30-2005 12:39:34
I have a M-F 35 Deluxe. The battery is drawing a heavy load when connected and that's without the switch turned on! Does anyone know where I can aquire a simple wiring diagram for this thing? My next question is, "is this a Neg. or Pos. ground tractor?" I think it's a 1961 model.
Serial #: SGM 217898
Model #: MF-35
ILL John
10-30-2005 17:41:57
 Re: wiring diagram in reply to having problems, 10-30-2005 12:39:34
I've got my Grandpa's TO35 Delux, have some owners and parts manuals, I can look to see if there's a diagram in the books. John
having problems
10-31-2005 04:54:25
 Re: wiring diagram in reply to ILL John, 10-30-2005 17:41:57
Well Mr. ILL John, if you could look for a diagram I would greatly appreciate it.
twopop
10-30-2005 15:42:29
cant help you with a diagram or battery ground,however,does it have a generator?if so,loosen the generator belt,then hook up battery.if the generator turns,your voltage regulator is stuck,need to replace.
