Tractor Talk Discussion Forum
Connecting Brake Lines
Tweeter
10-30-2005 14:58:47
How do you connect the steel brake line on a pickup truck to the rubber brake hose that goes to the caliper? Mine is rotted away.
old
10-30-2005 15:05:31
 Re: Connecting Brake Lines in reply to Tweeter, 10-30-2005 14:58:47
Depends on the truck. On a chev theres a pipe nut that does that.
Tweeter
10-30-2005 15:13:53
 Re: Connecting Brake Lines in reply to old, 10-30-2005 15:05:31
The truck is a 1987 Ford F250.
old
10-30-2005 15:34:40
 Re: Connecting Brake Lines in reply to Tweeter, 10-30-2005 15:13:53
Should have the same sort of thing. Just trace the line up to where it hooks to the frame etc and you should see where you can disconnect to 2 of them. Every car/truck I have ever worked on where the same and I've done almost all brands at one time or the other.
ray in ct
10-30-2005 16:21:49
 Re: Connecting Brake Lines in reply to old, 10-30-2005 15:34:40
Yep you need a male pipe thread on the brake line 1/8 npt. Just follow the line to where it connects to the frame like "old" said. If the lines are shot I bet yah the bleeder's will be too. Just did the lines on my 88 F250 last weekend every bleeder valve snapped off with minimal torque applied.
old
10-30-2005 17:01:07
 Re: Connecting Brake Lines in reply to ray in ct, 10-30-2005 16:21:49
Bet I could have gooten the bleeders loose with out brakeing them. Yes theres a trick to it. Next time before you put a wrench on them smack the s$!t out of each of them with a hammer. So far if I do that I have never braken one off. Got that from a guy that died years ago like most of what I know how to do and tell you guys on here.
RustyFarmall
10-31-2005 04:28:57
 Re: Connecting Brake Lines in reply to old, 10-30-2005 17:01:07
A brand new slave cylinder only costs a little bit more than a rebuild kit, why mess around a rusted and stuck unit only to end up with something you can't use anyhow?
