Tractor Talk Discussion Forum
Case VA wheel weights
Jason, NW Ontar
10-31-2005 06:32:57
Were there different rim sizes on these machines through the years? I've got the 28" rims, and the four mounting holes on the hub are 7" apart. Does anyone know if these are standard? Do I have to search for Case weights, or was this a common mounting scheme with many companies? Thanks for any input.
jcmarleau
10-31-2005 19:21:22
 Re: Case VA wheel weights in reply to Jason, NW Ontario, 10-31-2005 06:32:57
Hi Jason I do have wheel weight for the va.my e mail is jcmarleau@aol.com
Josh H
10-31-2005 08:26:43
Your gonna need Case weights, but VAC's are pretty common and use the same 28" wheels and weights as your VA. I bet you can find some VAC weights without much trouble.
