Tractor Talk Discussion Forum
Schramm tractor
Rob in Missouri
11-03-2005 19:58:39
I recently came across a Schramm Pneumotractor.
It is six cylinder,part engine and part air compressor. Does anyone know anything about this tractor? What were they used for? Are they collectible? The owner wants to sell it but we have no idea what it might be worth. I would appreciate any information or suggestions.
Sam Hardgrove
02-05-2006 19:32:37
 Re: Schramm tractor in reply to Rob in Missouri, 11-03-2005 19:58:39
FYI- We have manual's, and, parts if needed.
Contact Frank McBride @ 817-370-2039 for detailed info. on any Schramm machine. He worked for Schramm for 45+ years.
Thanks,
Sam
Lena's Warehouse Part's
817-713-3765
PS- call Frank after 11:00am Cst, he sleeps in.
jim arras
11-08-2005 13:20:32
If you get me the serial number I can tell you what year it is. I would try to buy it if you can, I have a model 160 and also a model 60 crawler. Good luck Jim Arras
Rob in Missouri
11-06-2005 14:16:03
Thanks for your information. I will talk to the owner Saturday and see if we can reach an agreement. Thanks again.
Jeff Oliver
11-04-2005 19:22:54
Got a friend with one. he was wanting ot find a regular head for it and make 6 cylinder puller out of it. Couldn't figure out which head to use and i think three if the cylinders would have been hard to convert. Neat machine though!
JeffLTN
11-04-2005 12:47:11
Ah yes the old Schramm Pneumatic tractor. I fisrt laid my eyes and hands on one when I was stationed at Barbers Point Naval Air Station in Hawaii. It was 1976 and I was assigned to an antisubmarine patrol squadron. The Navy had a few of these tractors on every Naval Air Station. They were great because you could drive your comressed air source to the airplane wherever it was parked and also tow several other pieces of ground support equipment and tools behind it. I quickly learned to love the ugly little rascal. One bonus feature was the rearward center of gravity, it doesn't take an 18 year old boy long to find out how to wheelee one of those things. Sadly, I found out it doesn't take the shop Chief long to catch you dioing it and slap the $&^%**#@ out of you.
For those that don't know the Schramm had a straight six cylinder engine the forward three cylinders powerer the engine, the aft three compressed air into a huge accumulator tank. That tractor usually spent abuot 14 hours a day running as a compressor and another 2 dragging gear around the flightline (or doing wheelees)lol!
RustyFarmall
11-04-2005 06:59:46
No idea of the value, but I would sure try to get it if I were you. Make an offer, if he doesn't accept, make a higher offer, eventually you and the seller will arrive at a figure that is acceptable.
Bob M
11-04-2005 06:13:54
That's Schramm “Pneumatractor” indeed! Seems every town highway dept around here had one back in the 50’s and 60’s.
They used a standard IHC truck engine modified to run on the front 3 cylinders with back 3 cylinders compressing air. As a tractor they were kinda underpowered and clumsy. And they did not have the air capacity of a dedicated compressor unit of similar cost. However the Pneumatractor’s ability to move itself around, to pull other equipment and to perform light blade work made it a very handy for highway departments, railroads, on construction sites, etc.
I submit a Pneumatractor would be very collectable. I recall only seeing 1 or 2 in my 15 years of visiting old iron shows. Certainly more unique and interesting than yet another styled A or Farmall H! And it’s being an “assembled” machine - assembled from other manufacturer’s standard products – most repair parts should still be available.
I say go for it!
Galen
11-04-2005 05:18:02
Had one at the place I used to work. Handy thing to have around, if you needed a portable air compressor. We did highway striping and tar repairs, so we needed it.
Bob
11-03-2005 21:27:59
I've only seen one, and that was a LONG time ago!
Try typing "Schramm" into the search box at the top of this page. They have been discussed quite a bit on this site over the years.
