Tractor Talk Discussion Forum
Allan, next question...
Dug
11-05-2005 14:15:06
I successfully installed the PTO extender! The plug in the pump was made of a soft material and I cut it out with a chisel...
Now that I have the extender on I need to shorten the PTO shafts from my implements (rotary mower, auger etc.) Any suggestions on cutting the material?
I'll post this on Implement Alley as well.
Thanks for all your help,
Dug
Allan in NE
11-05-2005 15:12:32
 Re: Allan, next question... in reply to Dug, 11-05-2005 14:15:06
Hey! Glad ya got 'er on.
I just use a hacksaw or a mini-chop saw; the material is real easy to cut. Make sure you don't cut it too short and cut the same amount off both pieces.
When the rig is setting straight ahead, that is the shortest that the shaft is ever gonna be. So, just measure to allow enough to let you put it on and take if off and you're set. Wack away! :>)
Allan
Dug
11-05-2005 19:19:40
 Re: Allan, next question... in reply to Allan in NE, 11-05-2005 15:12:32
The machine side seems to be solid steel about 1 1/4 inch square. I'm afraid the hacksaw method would kill me... : -)
I'm gonna try the grinder tomorrow, I think I have a cutof blade in the barn.
Again, thanks for all your help...I'd still be in the "stone ages" without ya!
Dug
LBS,IA.
11-05-2005 15:29:54
Your shaft is shorter when turned as sharp as possible.
fixerupper
11-05-2005 16:39:28
 Re: Allan, next question... in reply to LBS,IA., 11-05-2005 15:29:54
Or when mowing down into a ditch and the rear of the tractor hits the bottom of the ditch but the mower is still coming down the slope. I found that out the hard way this summer.Jim
