Tractor Talk Discussion Forum
OT, 93 Ford diesel pickup with high speed miss.
mlm
11-06-2005 09:25:33
The diesel idles good. Pushing it on a highway it misses. Has 175000miles. Think it needs new inection pump?
Davis In SC
11-07-2005 18:18:09
 Re: OT, 93 Ford diesel pickup with high speed miss in reply to mlm, 11-06-2005 09:25:33
I remember a friend had a similar problem on a 93 or 94 Ford... Turned out it was caused by oil foaming, causing a problem with the hydraulic- activated injectors... Ford dealer put Ford oil in it, & the skip disappeared, he said...
Bob/Ont
11-06-2005 09:38:52
Have someone else drive it and you follow in another vehicle to see what comes out of the exhaust when it is missing.A bad Camshaft can give a high speed miss too. How is it when you have it under load on a hill?
Later Bob
d-c-741
11-06-2005 20:07:39
 Re: OT, 93 Ford diesel pickup with high speed miss in reply to Bob/Ont, 11-06-2005 09:38:52
You are saying it has a miss at high way speeds,You should only slow down enough to get it turned in to the closest DODGE Dealer,before it Blows Up,or bends a Rod,Sorry but my father in law ,had the same problem with one with 8000 miles Ford Never got it fixed,when it had 15000 on it ,it was traded at Corry,Pa. Dodge dealer,it was fixed then!
