Tractor Talk Discussion Forum
OT- 71 Ford 360 tune up
Ted Del
11-06-2005 11:33:24
Does anyone know the tune up specs for this engine?
Timing
Plug Gap
Points settings
Thanks very much!
Ted
John SD
11-06-2005 18:39:23
 Re: OT- 71 Ford 360 tune up in reply to Ted Del, 11-06-2005 11:33:24
Ted, IMO the best thing you can do tuning up your 360 is put a Pertronix Ignitor electronic ign conversion in your distributor instead of another set of points. I made the conversion a couple years ago on my '73 390. Cost about $80 back then. Couldn't keep points in it before I made the switch. They just don't make points like they used to.
evielboweviel
11-06-2005 15:40:20
something to watch for is the oil pump will start dragging and wear the gear on the distribitor allowing the timing to change also wears out the timing chain. Tore my 68 clear apart to find this out. still in pieces and will be sold that way
Ron
Keith-oR
11-06-2005 13:35:31
Ted, don't have my truck manual handy, but tune up on Ford 360 should be the same as 390, same engine just difference in cubic inch. Same spec.s for both auto and standard trans. HTH
Timing----- - 6 degrees BTDC
Plug gap----- .034
point gap---- .017
Keith
Ted Del
11-06-2005 14:37:56
 Re: OT- 71 Ford 360 tune up in reply to Keith-oR, 11-06-2005 13:35:31
Thanks for the reply!
