Tractor Talk Discussion Forum
Farmall Super MTA
woodrow231
11-06-2005 19:33:41
A friends father recently passed on and his son asked if I would be interested in buying his old Farmall Super MTA. It is set up to run a grain auger off an aux.pump off the pto. No three point. Tricycle type. It has been stored for 15-20 years. What to look for and what do I do prior to trying to start it?
woodrow231
11-08-2005 19:02:57
 Re: Farmall Super MTA in reply to woodrow231, 11-06-2005 19:33:41
Thanks guys for the input. Will let you know how things go with SMTA.
Don L C
11-07-2005 15:44:34
Woodrow231.....it doesn't sound like you know anything about the Farmall letter series tractors!
that SMTA Farmall was only made one year, 1954...
there can be costly repairs, but a collector for sure.....you didn't say the price but if in good condition I would guess in Southern Ohio --- $3500.....
sammy the RED
11-07-2005 09:21:04
Buy it !
old
11-06-2005 21:01:33
Well if it hasn't been run in 15-20 years the first thing I'd do before even tring to turn the engine over, would be to fill the cylinders with tranny fluid and let it sit a couple days. Doing that helps unstick rings and valves and lubes the cylinder so you not dry staring it.
Uncle
11-07-2005 16:41:42
 Re: Farmall Super MTA in reply to old, 11-06-2005 21:01:33
If you get it running ,better check to see if the TA works, costly repairs and a pain in behind, probably doesn't have power steering and the MTA is a bummer to steer if it doesn't have it, I don't see all the buzz with the MTA , ours is a crappy tractor, I'd take an M anyday. Uncle
