Tractor Talk Discussion Forum
What does tire size indicate?
Cormac
11-08-2005 03:08:33
I am about to replace rear tires on my tractor. It currently has 16.9 X 30. I saw once that the OEM tire was an 18.4 X 30. I am guessing both are for a 30" wheel. What do the other numbers indicate? Which is taller? Which has more width? Is one size preferable over the other?
Nebraska Cowman
11-08-2005 04:46:46
 Re: What does tire size indicate? in reply to Cormac, 11-08-2005 03:08:33
the first number is the width measured at the widest part of the sidewall. You are correct the 2nd number is the rim diameter. The 18.4 tire will be slightly taller too. Have your tire dealer show you both sizes if he has them in stock.
