Tractor Talk Discussion Forum
O/T 88 ford ranger
twopop
11-09-2005 18:59:54
help I have an 88 ford ranger v6 2.9 A/T engine floods between 35 and 55 mph had it to two shops,no help does not show any codes,tps checks good map checks good coolant sensor good fuel pressure good need some input thanx
dave
twopop
11-10-2005 16:05:42
 Re: O/T 88 ford ranger in reply to twopop, 11-09-2005 18:59:54
Ive had a problem with getting kicked off line ,so maybe will have to post several differant times.tried the air charge sensor,no change.yes im sure it is flooding,yes lots of black smoke,have to go out off town tomorrow so wont work on it til sat.
twopop
11-10-2005 16:08:17
 Re: O/T 88 ford ranger in reply to twopop, 11-10-2005 16:05:42
tried to get a new tps.two are called out for 88.spossed to get the ford number off of old one to find out which one,it had been changed before and no numbers on it fomoco no help
onefarmer
11-10-2005 12:55:25
 and..... in reply to twopop, 11-09-2005 18:59:54
....let us know how you come out.
NEsota
11-10-2005 11:04:16
Two problems with my high-mileage Ranger that exhibited strange symptoms were due to the following: (1) The plate in the distributor that turned to advance the magnetic sensor had worn suspension and when pulled by the vacuum actuator it cocked side ways changing the tangent angle to the cam. (2) Vacuum leak on intake manifold. That is an easy one to check for.
onefarmer
11-10-2005 08:08:50
I had 86 ranger 2.9 acted exactly like that. Miss and sputter at speed but ok at idle. Dealer replaced the o2 sensor and some wiring. After three visits, $500 and no fix I gave up on the dealer. I decided to start changing sensors myself. The problem was the air temp sensor in the intake. On mine it's located on the right side(passenger) of the intake manifold. Fixed it right up for about $20. Glad it was the first one I changed.
onefarmer
11-10-2005 12:54:12
 some more thoughts in reply to onefarmer, 11-10-2005 08:08:50
PS Mine didn't show any codes either. I had the 2.9 AT. 300,000 miles
Are you sure it is flooding? What is it doing? Is it blowing black smoke?
That is what mine was doing. My problem was I couldn't see the smoke until someone I knew followed me and mentioned it.
If you think of the things that could effect fuel mixture without throwing codes, these are the things to look for. In my case the air charge sensor was to culprit. Could be o2 sensors, throttle position, water temp sensor, thermostat not warming the engine to temp.
bradk
11-10-2005 05:46:29
Seen clogged catalytic converters and collapsed lower air-box intakes on these trucks.Is it smoking black?Are you sure it's flooding , and not running out of fuel?How is your fuel volume?Older injected vehicles burning E-85 will act like this if put in by mistake.~brad
