Tractor Talk Discussion Forum
Backhoe OK, now help my car!
Andrew H
11-10-2005 13:10:13
All of you have been helpful with advice for my Ford 550. It ran well this summer, and I got alot of work done. Thanks to you all.
Now I need a bit of help with one of my cars. I left it for 8 months with gas in the tank and no fuel stabilizer. I tried to start it this week, but it won't catch. There is some smoke from the exhaust, but it doesn't turn over and ignite. OK, I already put in new gas. I figure the fuel injectors are gummed up? It is a V8 EFI motor.
Any hints on unblocking those injectors or any other hints? Any other ideas on what might be the problem? Thanks guys!!!!
Andrew
Mike7468
11-11-2005 07:24:12
 Re: Backhoe OK, now help my car! in reply to Andrew H, 11-10-2005 13:10:13
HAve you tried to spray any starting fluid into the air cleaner? Plugs?
xragman
11-11-2005 06:28:19
It should work on 8 month old gas if starter turn it ok. I would first check for water in fuel system.
jfp
11-10-2005 16:50:02
The guys need to know what kind it is and what if any tests you have done? Checking fire, fuel, reset buttons if battery was unhooked or not etc. ?
