Tractor Talk Discussion Forum
John Deere 4020 tractor and John Deere Auger
Kathy DeSmet
11-11-2005 07:34:44
I need replacement parts for these two items. A new front axle for the 4020 tractor and a new wheal for the auger. They were purchased in 2004. Do you know of anyone who repairs these?
Thanks
Tx Jim
11-12-2005 03:40:59
 Re: John Deere 4020 tractor and John Deere Auger in reply to Kathy DeSmet, 11-11-2005 07:34:44
Kathy,I have a factory wide frt. axle that hasn't been broken that I can sell you for $750/shipping. If interested contact me hayman@htcomp.net HTH,Tx Jim
John A.
11-11-2005 20:59:12
Kathy, Get in contact with Abilene Machine @ Abilene Kansas. You didn't say weather or not you 4020 has a loader on it. If you do this the only way to go!!! Most of the time the upgrade is from the heiver 30 series tractors like a 4230 would have. You will never have a frontend problem again! Good luck, Hope this helps.
Later,
John A.
JMS/MN
11-11-2005 17:53:49
I had the front axle on my 3020 welded years ago- added some reinforcing strips and it stands up ok, but check with salvage yards for a heavier unit- like from a 4320, 5020, etc. Can access 11 yards at 1-888-845-8456. Many other yards around the country as well. Google for tractor salvage yards.
720Deere
11-12-2005 14:09:32
 Re: John Deere 4020 tractor and John Deere Auger in reply to JMS/MN, 11-11-2005 17:53:49
The 4320 wide front is the same. That wide front was used from the 2510 to the 4320. The 4520, 4620 & 5020 all have a different heavy front end with different steering that takes a lot of work to make fit and work on a 4020.
paul
11-11-2005 09:53:46
Do you mean the rim that a tire mounts on for the auger - you mean a grain auger? Is it a standard size rim, 4, 5, or 6 bolt holes? Or is it a special rim with just a sleeve hole through it?
The front end: Many get welded back together. Looks kinda rough. Many get replaced with one from a salvage yard. There are 1000's of ag salvage yards across the country. Many get replaced with a stronger front end from a slightly different JD tractor (I assume you have a loader on the tractor....). But I'm not up on JD very well, so can't say what or how.
--->Paul
Christos
11-11-2005 08:04:52
Kathy, Other than the 4020, try and find out the model number/brand of the auger and if its a JD, run it through www.jdparts.com . If you don't have a password/login name for that its really worth it - just type in 4020 (and whatever the auger is, that is if its a JD) in the model search and you should be able to find the parts you need using the sectional index.
Christos
