Tractor Talk Discussion Forum
Re: Cold Diesel Engine Again
kyhayman
11-14-2005 07:06:02
Sounds like the same type of thermostart heaters that are on my Fords, Case/David Browns, and Cats (using 3404 Perkins). Normally takes about a 45 secs of preheat and then 45 secs of cranking to start at 30 deg F. Two heat cycles and t crank cycles at 15, 4 cycles at 0 and so on. If you lose any cranking speed at 4 cycles check batteries and connections.
