Tractor Talk Discussion Forum
12 Volt voltage regulator
Kenneth R. Grez
11-14-2005 18:09:24
Can I use a 12 volt voltage regulator that was used with a 12 volt generator on a 12volt alternator?
John T
11-15-2005 05:20:32
 Re: 12 Volt voltage regulator in reply to Kenneth R. Grezenski, 11-14-2005 18:09:24
Kenneth, a Generators (DC Voltage) Voltage Regulator regulates how much effective Field Current flows through the gennys Field windings plus serves as a cutout relay to connect the genny to the load once its voltage exceeds that of the battery, but disconenct it otherwise like when the tractors off so the battery dont reverse discharge through the genny. An alternator (AC Voltage) is a whole different animal using slip ring type "brushes" and the rotor induces AC voltage into the Stator. I agree theres no way (unless totally modified and redesigned) you can hook up a DC VR to an alternator n make it work properly.
Why not use an internally regulated Alternator?? Most are for Negative ground remember.
John T
Bob
11-14-2005 22:05:29
Almost cetainly NO.
