Tractor Talk Discussion Forum
Re: hard--no very hard starting oli 1850 Deis
Hurst
11-16-2005 18:19:39
Timing is what the problem is. I bet that the timing got changed when they rebuilt it. Did you line up the timing marks when you installed the pump? If not, then do so. Most pumps have a cover with 2 dashes, once they are lined up with the engine at a certain angle, you are good to go. off timing will cause a really hard starting tractor and a loss of power when cold and when hot too.
Hurst
