Tractor Talk Discussion Forum
Hub on axle of model g john deere
Don Archer
11-17-2005 17:03:21
I have a 1946 g john deere that i can not get the hubs to slide on the axle i have tried oil wd 40 wheel pullers but no heat any info would be appreciated they are rusty but dont look that bad
matthies
11-17-2005 20:00:52
 Re: Hub on axle of model g john deere in reply to Don Archer, 11-17-2005 17:03:21
If it runs, drive it around a bit even with the puller on, works everytime from an A to 4555 JD.
Bob
11-17-2005 18:44:55
1.) Use some REAL loosen juice like PB Blaster, Kroil, or Thunderbolt. (Save the WD-40 for, well, err, well, I can't think of what you'd save it for!).
2.) When you get tired of trying to pull it off, get a section of heavy-walled pipe that will slip over the axle, and up against the hub, and whomp on it with a large "fitting tool" for a while. If it still won't budge, repeat #1, then try pulling on it again, then try #2 again 'til it lets go.
Dean Uhl
11-17-2005 18:33:14
Take Rim off the wheel, remove clamp bolts. Clean the axle like new, Install puller, and hammer on inside of the wheel, in cojunction with puller,
730 virgil
11-17-2005 20:33:45
 Re: Hub on axle of model g john deere in reply to Dean Uhl, 11-17-2005 18:33:14
is this a splined axle ? if you haven't cleaned all the dirt and grease off do so you might be surprised at what you find as crazy as it seems someone welded the hub on my a to the axle i ruined a good log chain until i found that out
