Comments on Howse bush hog
Phil in MS
06-16-1999 05:57:30
Looking at 10 foot Howse bush hog! Need comments
pro or con about this brand! Thanks!
clancy
05-09-2004 19:00:50
 Re: Comments on Howse bush hog in reply to Phil in MS, 06-16-1999 05:57:30
Please dont get taken like I and everyone I have talked to. The HOUSE BOSS 10 FOOT was a peice of junk. 90 day warranty. Within the first 5 hours the right blade assy. dropped off, the gearbox couplers came apart, the trailing wheels came apart. had to rebuild the right gearbox, and now the output shafts are loose again. The universals on the p.t.o. shaft are bad. I'll swear I havent used this bush hog 35 hours. A friend carried his back to the factory twice. I also have a covington cutter 5' I have used for 23years.
HOWSE stuck me for 2000.00 but they will never do it again. good luck.
Sammy
06-16-1999 10:25:09
I bought a 6 foot Howse earlier this year and have cut with it about 5 times now and love it. Maybe I havent had it long enough but so far it is doing great. This was definitely the most cutter for the money because this cutter has a 100 HP gearbox and all of the other brands in this price range had 45 HP gearboxes which is the main reason I bought along with good reviews from people that I knew that had Howse implements. Well good luck
kaye Truly
08-18-2002 12:08:07
 Re: Re: Comments on Howse bush hog in reply to Sammy, 06-16-1999 10:25:09
How can I purchase a baring for the back wheel on a Howes bush hog Model#400 Serial #0919940206. Thank you for your reply Robert Truly
ltf in nc
06-16-1999 07:23:50
Howse rotary cutters are BAD news. Do NOT buy one. They are noted for coupling problems between the gearboxes. The overall quality is marginal at best.
Redneck
06-16-1999 10:05:44
 Re: Re: Comments on Howse bush hog in reply to ltf in nc, 06-16-1999 07:23:50
I agree. I have a 6' and it was cheap. Would be ok for some one who just cuts a little, but if you want a dependable bush hog spend a little extra and get a good name brand bush hog.
Phil in MS
06-16-1999 10:29:42
 Re: Re: Re: Comments on Howse bush hog in reply to Redneck, 06-16-1999 10:05:44
Thanks, Guys for the info! I currently have and would keep a 6' Ford that does a good job in both light or heavy cutting! A friend and I are looking for a 10' cut to use on pasture. He has an older 13'rigid frame which is a pain to road and get thru gates. Since I plan on keeping the 6' 3PTH Ford for sapplings, the 10' unit would be used on grass, briars, and sage grass pastures! Sometimes would be a heavy load and sometimes not!
I really don't mind paying extra for quality, however! The price on the Howse seemed good, BUT I didn't know anything about them!
Thanks again!!
James
06-16-1999 17:49:13
 Re: Re: Re: Re: Comments on Howse bush hog in reply to Phil in MS, 06-16-1999 10:29:42
I learned in marketing that when a company is so well known that their product is used synominously with the product made by others, then you've got a great product. For example, many call it clorox instead of bleach, kleenex instead of tissues, and in this case, you all are calling it a bush hog instead of a brush cutter. Take a look at a real bush hog, manufactured by bush hog. I don't own one, I own a sidewinder, but if I ever can justify a new one, it will in all likelihood be a "Bush Hog" brand.
