Tractor Talk Discussion Forum
farmall A serial number
Sandy White
11-20-2005 10:45:32
I have a Farmall A. But I don't know what year or anything about it. Can someone tell me is there away to find out what year it is?
old
11-20-2005 10:53:57
 Re: farmall A serial number in reply to Sandy White, 11-20-2005 10:45:32
Serial number should be under the seat on the right hand bracket, or at least I think its the right hand one but any how thats where it is if it hasn't been taken off. With that and looking on the lft of this page under serial number you should be able to find the year that it is.
Sandy White
11-20-2005 11:35:40
 Re: farmall A serial number in reply to old, 11-20-2005 10:53:57
There is no tag on the tractor any where. Can I find out what year by parts casting numbers?
Dave H (MI)
11-20-2005 18:59:13
 Re: farmall A serial number in reply to Sandy White, 11-20-2005 11:35:40
You can also look for an engine serial number. If it is under a certain number, the tractor and engine matched serial numbers. You should be aware, however, that the A, B, and C had a lot of interchangeable parts so castings, engine numbers, and even the actual tractor serial number (since it was on a removable bracket) may not be original to the rest of the tractor. In the end you will only be guessing based on what I tend to call "overwhelming evidence" that the tractor can be credited to a certain year since most of it's parts are coded to that year. I was at a scrap yard recently where every Farmall B and BN on the place had a serial number that started with "FAA" for the Farmall A. Do your best and enjoy your tractor.
old
11-20-2005 11:46:17
You can get a good ball park idea of the year by casting numbers. They will be something like this. 9-11-G ---where the 9 is the month the 11 the day and the G is the year. I don't have a list for date codes but if you post that infoi some one will.
Sandy White
11-21-2005 19:37:16
 Re: farmall A serial number in reply to old, 11-20-2005 11:46:17
Thanks old for the follow up!
