Tractor Talk Discussion Forum
glow plugs
l245dt
11-21-2005 09:39:08
how do i know when its time to replace glow plugs?
bradk
11-21-2005 11:53:42
 Re: glow plugs in reply to l245dt, 11-21-2005 09:39:08
They need to be replaced when they burn open(won't accept current flow).I use a multi-meter on the ohm setting-or the "cave man method"is a long piece of heavy gauge wire connected to B+ side of battery & see if it arcs when touched to the glow plug terminal.~brad
Blue guy
11-21-2005 18:11:47
 Re: glow plugs in reply to bradk, 11-21-2005 11:53:42
I use a 12 volt test light. Pull the wires and clip the test light to a hot source and touch the end of the glow plug. If you have no light you have a bad plug.
