Tractor Talk Discussion Forum
Diesel Spill
B. Carll
11-23-2005 18:00:45
Well today I came home to mess. I had diesel fuel delivered and somehow they spilled several gallons on the ground and around the foundation of the house. The whole house really smells of diesel and the ground is covered by the spray when it came out of the tank. Any suggestions how to treat this spill and how to get rid of the odor. To date I hosed everything down with DAWN dish detergent and rinsed but think I'm going to need more than that. Help if you can?
Bob C.
James2
11-24-2005 09:02:39
 Re: Diesel Spill in reply to B. Carll, 11-23-2005 18:00:45
This is an issue at work because we operate experimental machines. Small spills can be left, the soil microbes will eventually eat the carbon up, although any heavy metal additives will remain. I'm not member of the Hazmat response team, but I believe a couple of gallons doesn't require cleanup, seems like the trigger point is over three gallons, but I could be wrong. The big problem is if it happens several times, since you are in a fixed location. You shouldn't have tried to use detergent to emulsify the fuel which could allow it to be carried deep. Like others reported, for large spills the dirt is removed and incinerated, which is very expensive. You could build a large trash fire, and slowly feed the contaminated soil in, which will do a pretty good job. If this ever happens to me, I probably will go this route. I'm not sure it's legal, but I would consider removing the worst dirt and spreading it far from the house, over a large area, which would accelerate the breakdown. Over a large area, any subsequent testing would not find any problem. In California, I'm sure this would be frowned upon. But as I said, small spills can be ignored. Replace with uncontaminated dirt. However, be sure to let the fuel company know this is the last mistake, or build a container around the tank to catch any spills as was suggested. It could require some effort on your part, and it depends on how much you like the fuel supplier. I personally don't like to use a heavy hand and slap someone whom makes a manageable mistake the first time. In my opinion, calling or threatening to call the authorities immediately, is just as bad as yelling, "I'm going to sue" for any small infraction. A more Christian attitude seems to be the better play.
john in la
11-24-2005 04:42:00
Call the supplier/delivery company right away.
It is his problem.
While they may have had a case at the time of the spill; (you ordered more than the tank would hold; you did not provide a strapping chart so the driver did not know how much the tank would hold) the moment the driver left your place they messed up.
Any and all spills must be reported to the company and cleaned up. The proper way to treat dirt is to dig it out and incinerate it on or off site. If the EPA finds out about the spill in the future you will have the bill because it will be to late to go back on the delivery company.
If the supplier gives you any heartache just tell you will need to call the law and that should get them moving. The EPA will make them remove and replace the dirt.
By the way I would not mention you tried any clean up action.
As a side note..... ..... ..
I recommend all tanks be put on a slab with a cinder block wall high enough to hold all product in the tank. It reduces the chances of your yard becoming a EPA superfund clean up site.
37 chief
11-23-2005 20:52:51
If I were you I would dig it up and place it on a piece of plastic before it soakes any further into the dirt. then contact the supplier. Stan
Gene Davis (Ga.)
11-23-2005 18:25:18
You should put this cleanup problem back on the supplier. That sort of spill is probably classified as a haz-mat problem by the EPA and it could become a sticky subject for him if he does that in other places also.
john in la
11-24-2005 04:46:05
 Re: Diesel Spill in reply to Gene Davis (Ga.), 11-23-2005 18:25:18
There is no "probably" about it.
oldrustycars
11-23-2005 19:43:55
make the supplier clean it up. this sort of thing can really bite you in the butt later on.
B. Carll
11-24-2005 16:11:50
 Re: Diesel Spill in reply to oldrustycars, 11-23-2005 19:43:55
Well thanks for all the input --- I will be contacting the supplier tomorrow and talking to them about the cleanup. After seeing it in the daylight what happpened is someone wasn't paying attention when the tank got full and it sprayed out of the fill spout onto the side of the house and about a 10X10 area of leaves and grass. I have washed the side of the house down and foundation. I was afraid of the dyed diesel staining the siding. Next I removed the leaves that I feel caught most of the spray and bagged them to burn later. I feel comfortable that I have cleaned up the best I can at this point. Any saturation into the soil I think was minimal but how do you know for sure, I wasn't there to see exactly what happened. The odor of course is bad but even within a 24 hour period it has improved much. If you have suggestions about helping eliminate the odor I would appreciate it.
Thanks
Bob C.
SAH
11-24-2005 18:35:07
 Re: Diesel Spill in reply to B. Carll, 11-24-2005 16:11:50
I work in forestry and fuel spills happen alot in the woods so we always try and clean them up. There are several materials that can soak up fuel but there is on type that is made up of microbes that feed on oil and fuel (they like the carbon I think). If you put this stuff on it and and mix it in with the contaminated soil it will eat up the fuel and you shouldn't be able to tell there was a spill. We can get it in Canada but I am not sure about the States and if you want the name let me know.
