Tractor Talk Discussion Forum
Case SG ?
Scott Louque
11-24-2005 22:49:13
I found an old case tractor has SG on the hood Its very clear SG but this site shows no SG and i couldn't find the serial tag. anyone heard of one of these before.
Brian in Ohio
11-25-2005 05:31:14
 Re: Case SG ? in reply to Scott Louque, 11-24-2005 22:49:13
Case never produced a tractor called the SG. There was an SC. If you look on the driver's left side, stamped on the flange of the engine block, where it bolts to the trasmission, you'll find the serial number. If you take that number to DCTom on the Case board, he can look up the build card for that number up and give you more details about the tractor.
Paul Janke
11-25-2005 05:27:44
Case made an SC. Is the serial number tag still on the instrument panel? Others can tell you where the other numbers are on the tractor. I don't know enough about them to say whether or not they made an SG.
