Tractor Talk Discussion Forum
Farmall C
Cannonball
11-27-2005 13:40:24
The C will start, but very shortly after I let go of the the starter rod, it quits running. Also, when I pull out the start/stop switch, the ammeter shows a discharge before I pull on the starter rod.
FWIW-- the previous owner installed an alternator, but it has always worked well.
Any suggestions?
Thanks!
old
11-27-2005 15:13:45
 Re: Farmall C in reply to Cannonball, 11-27-2005 13:40:24
Gauge should read discharge brfore you start the engine with the switch on. Sounds like you need to check to make sure your getting gas to the carb, also check your spark it should be a nice blue spark. Either thing can cause your problem
