Tractor Talk Discussion Forum
wide front end conversion
anthony kretowi
11-27-2005 14:35:07
how hard is it to change from a narrow front end to a wide? I have a 1940 John Deere B, and have a 1952 JD B parts tractor with a wide front end on it. Will the 1952 wide bolt on to the 1940 without fabrication, or is it a bolt on affair? Thanks much.
farmerboy
11-28-2005 06:15:45
 Re: wide front end conversion in reply to anthony kretowicz, 11-27-2005 14:35:07
You could always fix up the 1952 unit. It's a much better machine anyhow.
A 1952 B has a split pedestal whereas a 1940 B has a solid pedestal. "Split pedestal" means the front end bolts onto the bottom of the steering post. A solid pedestal has the steering post solid from the gearbox at the top to the tires at bottom. If you had a 1939-1946 wide front, you would be able to change out the entire unit with a lot of labor but no mods. However, I'm fairly certain a 1952 will not bolt up to a 1940 without modification and a lot of cussing.
In good condition, that wide front is too valuable to do a lot of torching and welding on it.
Good luck whatever you do.
anthony kretowicz
11-28-2005 15:00:32
 Re: wide front end conversion in reply to farmerboy, 11-28-2005 06:15:45
Thanks for all the replies, guys. I guess I"ll wait on this job and keep her the way she is. Again, thank you for the advice, and have a very happy and safe holiday season
John in Md.
11-27-2005 16:04:59
Unless you have a two piece frontend they're not the same thing .The 40 had a one piece (anteater) frontend not the later split pedestal.
Island A
11-27-2005 15:10:46
You will have to use the split pedestal from the 1952 B, but yes, you should be able to do it. It should bolt right up.
I think....
Dave
Myrl (PA)
11-27-2005 16:07:09
 Re: wide front end conversion in reply to Island A, 11-27-2005 15:10:46
I dont think so Dave. I think the 40 B has a cast steel frame and the 50 B has a pressed steel frame and I believe the bolt pattern is different but not sure.
Myrl (PA)
11-27-2005 15:45:09
Island A
11-28-2005 09:30:03
 Re: wide front end conversion in reply to Myrl (PA), 11-27-2005 15:45:09
I don"t know, I seem to recall the split pedestal being offered as a seperate assembly for converting older tractors. I really don"t know the true answer. The best way to find out is to measure the units.
Time to buy a parts book!
Dave
