Tractor Talk Discussion Forum
Bigger tractor/same bush hog
jodyla
11-29-2005 00:51:06
I"m looking at getting a bigger tractor (120hp) that has a 1000 rpm pto. I currently have a Bush Hog brand 7 foot (model 287) medium duty cutter behiond a 4020. Bush hog is rated up to 120 hp. Is there any way to convert or adapt my bush hog to a 1000 rpm shaft? Do I need a whole new gearbox and shaft for the bush hog? Any idea what this would cost? My bush hog is fairly new - year old and used about 5 hours. I"d hate to trade it in and loose a bunch of money.
Tx Jim
11-29-2005 03:20:17
 Re: Bigger tractor/same bush hog in reply to jodyla, 11-29-2005 00:51:06
Jody,gearbox can probably be changed to 1000 rpm but you would also have to change frt. yoke on pto shaft. This will cost some $$$$$$. Is tractor you're considering 1000 rpm pto only? What brand and model? Tx Jim
Jodyla
11-29-2005 03:52:40
 Re: Bigger tractor/same bush hog in reply to Tx Jim, 11-29-2005 03:20:17
Yes its 1000 rpm only. Its a versatile 300. How much money for a gearbox and yoke (about)?
BobMo
11-29-2005 05:07:43
 Re: Bigger tractor/same bush hog in reply to Jodyla, 11-29-2005 03:52:40
Probably about the same as you gave for the original. I don't know how much area you have but I don't know why you want to use a 7' unit behind a tractor that big anyway.
I personally think you'd be better off going back to the dealer you purchased the original from and beg for mercy. The cost of conversion will go a long ways toward a 10' unit with 1000 rpm and then you'll have it right. Good luck which ever way you go....
nw_bearcat
11-29-2005 05:05:22
One option would be to either put an adapter on the shaft you have to take it from 1000 to 540, or put a 1000 yoke end on the shaft you have and only run the tractor at about 1/2 PTO speed. I'd think you'd burn alot of fuel with that large of a tractor on that size of cutter at full RPM
Jodyla
11-29-2005 17:28:42
 Re: Bigger tractor/same bush hog in reply to nw_bearcat, 11-29-2005 05:05:22
I guess the best thing to do is sell the 7 footer and gor for a 9 or 10 foot. The 7 is a bit samll even now. Thanks for the replies.
