Tractor Talk Discussion Forum
Zenith carb rebuild/drip plug neoprene seals
Kendog
11-29-2005 09:44:54
1. The parts catalog shows a felt & inner washer within the drip plug of the carb. I can see there is nothing other than the outer cover with the pinhole. Issue? Should a rebuild call for a repacking of a breathable material?
2. The neoprene throttle shaft seals installation instructions are not clear. Do you install them with the 'open' edge to the INSIDE or OUTSIDE? Based on the principals of vacuume, it would seem the open edge of the seal would be to the outside. Thank you.
Glen in TX
11-29-2005 13:43:05
 Re: Zenith carb rebuild/drip plug neoprene seals in reply to Kendog, 11-29-2005 09:44:54
The bowl vent plug on bottom is usually felt or just a brass porous disc that is center punched in place. Some kits come with that but many don't now. It just keeps dirt and bugs out of the bowl vent and leaves it so excess can drain out. The seals go as you suspected the the open lips to the outside of carb and smooth flat side to the inside. Otherwise it would allow air and dirt to be sucked in.
Kendog
11-29-2005 16:25:18
 Re: Zenith carb rebuild/drip plug neoprene seals in reply to Glen in TX, 11-29-2005 13:43:05
Good info. Thank you.
