Tractor Talk Discussion Forum
#2 Funace fuel in a diesel
IA Farmer
11-29-2005 19:06:34
Will it hurt to use some furnace fuel in a diesel engine? I have approx 100 gal. in my barrel and I am swithcing to an LP furnace. Can I blend this in with diesel? I use the tractor for light work.
Thanks
paul
11-30-2005 10:01:39
 Re: #2 Funace fuel in a diesel in reply to IA Farmer, 11-29-2005 19:06:34
True furnace fuel might not have some additives that help lubricate the engine, pump, etc.
In practice, _most_ fuel delivery places use the same exact fuel for both furnace fuel & diesel fuel. It is more expensive to handle 2 seperate fuel delivery lines than the slight difference in prices.
I'd say you will be fine with a bit of a blend or a fuel additive, and if you can ask the place that delivers fuel, you likely have #2 diesle fuel from the start.
--->Paul
Island A
11-30-2005 06:05:02
According to my Model 70D operators manual #2 fuel is a heavier fuel, with a higher BTU content, and you will get more HP/Hour with this fuel than with #1. So yes, you can use it just fine.
Dave
marty g.
11-30-2005 04:36:45
The die is applied from the delivery truck, it must be expensive color ;-) Your tractor won't see a difference, only your wallet...
Jay (ND)
11-30-2005 06:19:10
 Re: #2 Funace fuel in a diesel in reply to marty g., 11-30-2005 04:36:45
Wrong - the die is applied at the terminal, and not your fuel suppliers terminal, the terminal where they get it.
The dye is put in to tell the difference between off-road fuel and on-road. Nothing else. Your state may have a tax on house fuel and not on tractor fuel or vice-versa, but the fuel is the same.
Gary Schafer
11-30-2005 16:04:08
 Re: #2 Funace fuel in a diesel in reply to Jay (ND), 11-30-2005 06:19:10
Not entirely correct either? Some states used to mandate dye in fuel for off road use that contains higher sulphur than on road fuel. Not sure if there is still a difference now.
Regards
Gary
john in la
11-30-2005 18:50:30
 Re: #2 Funace fuel in a diesel in reply to Gary Schafer, 11-30-2005 16:04:08
Federal law mandates that high sulpher fuel can not be used for road use. Because of this all high sulpher fuel is dyed red.
Low sulpher fuel may be used for on and off road use. Because of the extra cost of tanks most suppliers only stock low sulpher. It is sold clear (green) for on road use and is injected with red dye at the loading rack for off road (no tax) use.
Red dye only tells you it is no tax (off road) use only. It can be low or high sulpher.
Jay (ND)
12-01-2005 06:11:27
 Re: #2 Funace fuel in a diesel in reply to john in la, 11-30-2005 18:50:30
Correct - thank you John
JMS/MN
11-29-2005 22:03:55
#2 furnace =#2 diesel. #1 furnace =#1 diesel.
J.C. IN AZ.
11-29-2005 19:23:58
The only one your use of either would matter to maybe would be the Tax Man!
john in la
11-30-2005 03:31:04
 Re: #2 Funace fuel in a diesel in reply to J.C. IN AZ., 11-29-2005 19:23:58
He did say tractor use so even the tax man will not care.
Now if he put it in his pickup the tax man would be mad.
Robert in Md
11-29-2005 19:18:04
I've been using No. 2 high sulfur fuel oil out of my furnace tank in my diesel tractor for years without any problems . It's the same thing, delivered in the same truck but the diesel costs about $.30 per gallon less for some reason. I ask for diesel when I fill my fuel oil tanks.
Aaron SEIA
11-29-2005 19:12:27
As far as I know, furnace fuel is #1 diesel. Some people that have basement tanks will run #2, but either way, it's just diesel and is fine in a tractor.
Aaron SEIA
Jay (ND)
11-30-2005 06:21:29
 Re: #2 Funace fuel in a diesel in reply to Aaron SEIA, 11-29-2005 19:12:27
No 1 and No 2 are different fuels. The numbers DO NOT represent a quality difference as they imply. No 1 will not gel as easily and is cleaner burning but has a lot less BTUs. No 2 is the way to go for most people and circumstances.
