Tractor Talk Discussion Forum
no power
hawksailor
11-30-2005 18:46:42
i have a 1943 ford fergusen i have replaced the plug wires with oem wires,spark plugs, dist cap,coil. have to jump start battery dead wont hold charge. after it runs awhile it sounds like it looses power especially if i engage pto could battery have something to do with this? please help
johndeerejon
12-01-2005 07:23:15
 Re: no power in reply to hawksailor, 11-30-2005 18:46:42
Make sure that all of your parts are compatiable, 6volt with 6 volt or 12volt with 12 volt. Also check your frame ground cable from the battery. If it does not have a good, clean connection it may affect the performance. Have you done a compression check?
old
11-30-2005 19:00:48
Well if the battery is bad and your genny system isn't working 100% then yes that could be your problem. Weak battery makes for weak spark weak spark makes for weak tractor.
Bob22
11-30-2005 18:52:19
Make sure you put plug wires back in correct order. If you didn't will probably run OK but have no power. I think firing order is 1-2-4-3 but not for sure.
620 row crop
11-30-2005 21:22:02
 Re: no power in reply to Bob22, 11-30-2005 18:52:19
double check the coil if it has 6 volt battery you need 6 volt coil
