Tractor Talk Discussion Forum
power steering on 800 ford
al bane
12-01-2005 08:35:54
I have an 800 Ford with an aftermarket power steering unit. I am wondering what type of fluid you would use for that.It has a seperate reservoir for the unit?
old
12-01-2005 08:50:08
 Re: power steering on 800 ford in reply to al bane, 12-01-2005 08:35:54
My 801 has a factory power steering and I use tranny fluid in it, I tried hyd fluid but that didn't work so went back to the tranny fluid. Don't know if that helps you or not.
al bane
12-01-2005 11:39:15
 Re: power steering on 800 ford in reply to old, 12-01-2005 08:50:08
Does the tractor you have--the 801 -- have the power steering connected to the tractor's hydraulic system or is it an individual unit not connected to the hydraulic system on the tractor and has its own motor and pump?
old
12-01-2005 12:15:05
 Re: power steering on 800 ford in reply to al bane, 12-01-2005 11:39:15
The power steering is a belt drive pump up front so ya its, its own unit Holds almost a qt of tranny fluid. I use dextron 3
