Tractor Talk Discussion Forum
Putting Rear Tube Tire on Rim?
BobG in VA
12-02-2005 12:30:30
First, It's been a bunch of years since I've done this, hence the request for info. I've got a good 36" Firestone F&R R1 tire I want to put on a spare Super C rim that I have. I got the tube this morning so I'm ready to begin. I'm all ears folks! Any do's and don'ts would be appreciated as I've pinched a tube in the "old" days and had to start all over again after fixing the tube. Thanks in Advance!! BobG in VA
Dave Sherburne,NY
12-02-2005 16:32:11
 Re: Putting Rear Tube Tire on Rim? in reply to BobG in VA, 12-02-2005 12:30:30
I just put new tires and tubes on front of a Super A. Tube instructions said DON'T use soap,
use vegetable oil for a lubricant. Bet nobody ever
read the instructions before.
BobG in VA
12-02-2005 15:34:48
Thanks for all the comments/recommendations. I had used a 4 1/2 inch angle grinder with a flap wheel on it to "sand" the rim to smooth on the inside and then used some aluminum colored anti rust spray paint on it. Today I wrapped the inside of the rim (where the tube contacts) with (of all things) duct tape. I'm glad someone mentioned the talcum powder cause I took a can out there today just for that reason. My compressor is regulated so I can maintain just enough air going in to do the job without it "goin' crazy" at 100 psi. Again, thanks for the comments. All are welcomed. I'll let you know how it goes tomorrow. PS. I also have to replace a front tube on the SC which I found today won't hold air anymore (got the tube at TSC). BobG in VA
gab
12-02-2005 15:02:29
A local guy got killed a couple years ago mounting a tractor tire. I don"t know what happened but I already had tires to mount on my Super C and it took a month or so to work up my nerve. In addition to your other advice recieved here I"d use one of those clip on tire chucks and stand around the corner where you can control your air compressor. I don"t think I"d oil the bead if I could find some soap. Jim
old
12-02-2005 13:17:16
Few things to do. Make sure you lube the beads of the tire before you put it on the rim. Soap and water or use a rag and some old oil either work well. Also after you have the tube in and both beads on air the tube up to the point you see the tire moveing the let the air back out. Doing that help pull the tube in to place before it can pinch.
Buster
12-02-2005 12:50:07
I put a light dusting of talcum powder on the tube before putting it in the tire, it allows the tube to slide in place easier. My 2 cents worth.
Hoosier JD
12-02-2005 14:02:21
 Re: Putting Rear Tube Tire on Rim? in reply to Buster, 12-02-2005 12:50:07
It has been a lot of years, but I put myself through college working in a tire store. First, we were told to never put any kind of oil on tires to mount them, especially car on truck tires, the tire might slip on the rim and lose the seal between bead and the rim, soapy water is fine...even recommended. Next, tire "spoons" are a great help, these are the specialized bars to pry the tire off or on. "Duck-billed" tire hammers are good for hammering the bead on, you can also use the hammer to break the bead loose from the rim, that's how I do all of mine here at home. As far as the tire-tube, make sure the rim is clean and rust free, pry or hammer on the first or back bead of the tire, insert the tube, put some air in the tube...just enough to take the slack out of the rubber with the valve fastened in the valve hole. Then carefully pry the front bead on. When airing the tire up, watch the beads and make sure they are seating against the rim correctly...if not, let it part way back down and try again. After the tire is fully inflated and seated, we were told to let the tire completely deflate to lessen the chance of the tube being wrinkled and pinching itself. Tire and wheel mounting is a very dangerous operation, if you can afford it, take it to the experts. I could tell hundreds of stories about guys getting injured working on wheels and tires. This not a complete or exact step by step explanation, and I get concerned when I hear of guys, no matter how mechanical or adept at doing things by and for themselves, tackle tire changing. Good luck. Mike
