Tractor Talk Discussion Forum
Re: 1987 Ford F-250 No Gas
Steve Crum
12-03-2005 05:21:56
You might want to make sure you don't have a fuel line connected to the rear brakes or something goofy like that. You don't say whether this is fuel injected. If it is, you may need to check and make sure you didn't knock a wire loose going to the in tank fuel pump. Or another thought is reseting the emergency fuel cut off switch under the dash above the clutch pedal on the firewall. This switch cuts power to the fuel pump(s)in the event of sudden fuel pressure loss from a ruptured line from an accident or other misfortune.
Tweeter
12-03-2005 09:23:04
 Re: 1987 Ford F-250 No Gas in reply to Steve Crum, 12-03-2005 05:21:56
No this engine is NOT fuel injected. It is a 351 Windsor with a 4bbl carb. I also found that it also has a mechanical fuel pump mounted on the front driver side of the motor that is cam driven. I squirted a little gas in the carb directly and it wants to fire and might run for a second then die out. As the starter is cranking, the motor seems to fire for a complete revolution then die and the starter keeps turning the motor.
