Tractor Talk Discussion Forum
FEL hydraulic layout simplification questions
Cormac
12-04-2005 04:54:28
I have a basic hydraulic skematic question that I am looking for some guidance. I have a Ford 6600 with a Bush Hog 2425QT loader with a two lever controller. I am confident that the pump pressure and return line are the two hoses that start/return just below the seat and go to the controller. It is the other four (cylinder hoses) I'd like to simplify. Right now they run from the loader to the back of the tractor (right past the controller) to 4 hydraulic quick disconects. On the other side of the quick disconnects I have additional runs of hose that follow the same path (now forward) to the controller. This means I have 8 lengths of hose between the controller and the back of the tractor. Here are my questions:
1)Since I do not have any implements that require rear hydraulics (at this time), can't I simply take the the hydraulic runs from the FEL and attach them to the controller. This would certainly simplify things and "clean up" the back of the tractor.
2)If for some reason you all feel that maintaning the rear hydraulics is important, can't I connect the FEL hoses to the controller with 4 pipe tees in the circuit somewhere near the controller (cleanly and organized) and now have 4 dead ended lines from the controller to the four QD's in the back should I ever require the use of rear hydraulics. With a total of 8 hoses running alongside the tractor (between the controller and the back of the tractor)with no clear and obvious location to secure them neatly, I am looking to eliminate an octopus back there.
Anyone care share an opinion?
big jt
12-04-2005 06:41:17
 Re: FEL hydraulic layout simplification questions in reply to Cormac, 12-04-2005 04:54:28
I am not specifically familiar with your loader.
Westendorf has a similiar setup. It is needed because when unhooking the loader you need control of the cylinders so the hoses need to reach as you back away.
Sounds like you are using good sense. Would for sure suggest that you keep the separate valve (controller) I have never been able to use the tractor remote valves very well to feather as well as a separate loader dedicated valve.
hope this answer isn't to muddy
jt
