Tractor Talk Discussion Forum
Farmall 560 making a terrible screeching noise
noahsark
12-04-2005 08:02:20
560 with a pto pump for a f11 loader, I was moving a hay bale when this really loud noise starts, it sounds like it's coming from the bell housing. The t/a is ok it drives, the pto shaft is turning but the loader will lift really slow.I'm going to spend more time on it later today....any thoughts? thanks
IH DOC
12-06-2005 17:36:12
 Re: Farmall 560 making a terrible screeching noise in reply to noahsark, 12-04-2005 08:02:20
I can tell ya what ya got there, the splines in the preasure plate that drives your pto & hyd. have worn out & when you put a load on them they are slipping & making a squealing noise. Yes you will have to split the tractor at the clutch housing & I would change the clutch, preasure plate , pto shaft which come out from the front of the ta housing & the pilot & through out brg., also the seal in the housing that holds that pto shaft. I would recomend having the flywheel refaced to while your in there too. Good luck with your project
smokieborde
12-04-2005 15:29:09
does the pto pump still work
if so check yoyr main filter on trans
my 706 did that i found out the trans filter was pluged
billyiron
12-04-2005 08:25:11
I will guess throw out bearing,or the livepower pto gear,had a 856 do what you describe, it was the pto gear,,,billy
Gus notti
12-04-2005 08:41:41
 Re: Farmall 560 making a terrible screeching noise in reply to billyiron, 12-04-2005 08:25:11
Well, do I have to split the tractor to fix it?
How can I access it?
Thanks
billyiron
12-04-2005 10:14:08
 Re: Farmall 560 making a terrible screeching noise in reply to Gus notti, 12-04-2005 08:41:41
yes youll need to split the tractor,,I would go to the farmall board for more expert help,,I only know enough to make me dangerous,,,billy
