Tractor Talk Discussion Forum
Briggs and Stratton Crankcase Gasket Replacement
Vinnie from NC
12-06-2005 08:06:16
I am replacing the crankcase gasket on a B&S twin. Does anyone recommend a particular gasket sealer or none at all? I was thinking of using the Indian Head brand of thin shellac on both surfaces.
Any advice is appreciated.
-Vinnie
doogdoog
12-06-2005 11:07:09
 Re: Briggs and Stratton Crankcase Gasket Replaceme in reply to Vinnie from NC, 12-06-2005 08:06:16
Aloha, For a more permanent seal, I would use the silicone type. If you want to remove it every so often and use the same gasket, you could use the indian head on the pan side and grease on the block side. That way, the gasket stays on the pan and usually releases on the block side (usually and not always). One thing to add is not to tighten it too much or you will distort the pan.
Mahalo,
doogdoog
ronnie269
12-06-2005 10:01:37
use 3M red, then if you have to work on it again it'l come right off, seals good to( it come's in a spray can-just follow instructions
ronnie269
12-06-2005 10:01:16
wfw
12-06-2005 08:49:31
I always use grease on my gaskets. Seems to seal good and the gaskets come off easily if you need to remove them later.
B. JONES
12-06-2005 08:47:58
I have used Fel-Cobond made by Fel-Pro and had good luck. The product is called Quick drying contact adhesive. I don't know if that is what you should use but it worked great for me. B. Jones
