Tractor Talk Discussion Forum
Propane vs Gas Engine Differences ?
MMB
12-07-2005 10:14:32
Can anyone out there explain how (and why) a propane powered tractor engine from say the 1950's is different that one that is gasoline powered? Is the compression ratio different and if so by how much? Are the heads or any other engine parts different?
RN
12-07-2005 11:23:40
 Re: Propane vs Gas Engine Differences ? in reply to MMB, 12-07-2005 10:14:32
Note also camshaft timing has no overlap to prevent backfire, Carb/fuel system different- LP liquid-to -gas relief valving/heat exchanger. RN.
buickanddeere
12-07-2005 19:08:25
 Re: Propane vs Gas Engine Differences ? in reply to RN, 12-07-2005 11:23:40
Deere kept the same cam timing with LP and gassers.
lpgasonly
12-07-2005 10:36:17
LP gas is a higher octane than gas. That is why it can use higher compression. It got a little more power out of the higher comp..Factory LP's got more comp. by either piston or head changes. Most used better exaust valves also.
Conversions soon followed because of the no carbon and longer oil and eng life. Also LP was a by-product of the refinery and sold dirt cheap. Another benefit was no one would steal your gas if you left the tractor out in the field.
colekicker
12-07-2005 10:18:01
Some tractors have different heads, pistons and intakes. It takes more compression of LP to get the same power that you get out of gas. Farmalls changed heads and pistons if you bought a factory LP. Maybe that helps.
Jon Hagen
12-07-2005 15:40:41
 Re: Propane vs Gas Engine Differences ? in reply to colekicker, 12-07-2005 10:18:01
A propane powered tractor will usually have higher compression to take advantage of the high octane fuel. Propane has no lead to lubricate the valves,so usually valves and seats were hardned. Propane goes into the engine as a vapor, so there is no need for any intake manifold heat. Cold air is dense air,so a heated intake manifold on a propane engine will actually hurt performance. Also a propane engine will usually have more initial ignition timing and may have a quicker advance curve. Most propane engines had the plugs gapped at a tight .015 because plug fouling was less of a problem and the shorter gap helped the spark jump the gap against the higher compresion/cylinder pressure of a propane engine. Some also ran a colder heat range plug because of less chance of fouling with propane fuel.
