Tractor Talk Discussion Forum
Exhaust port problems.
Mike in Ind.
12-07-2005 17:43:23
Need to know what my options are on fixing the exhaust port on my K181 kohler out of my cub cadet 70 garden tractor. The threads are badly corroded. The pipe threads in but barely holds. Figured on finding another block but might fix this one if its possible.Was thinking about JB Weld. Thanks for your help guys! Mike
Earl-IL
12-08-2005 21:13:15
 Re: Exhaust port problems. in reply to Mike in Ind., 12-07-2005 17:43:23
If the pipe thread in the block is loose cut a little off the muffler end so it will screw in deeper. They are taper threads. Earl In Illinois
Mike M
12-08-2005 04:22:30
Or you can try a new pipe nipple may need to cut it back to get good threads. Or have one threaded up and set the dies not as tight so the threads are bigger it may grab ahold of what you have then you can adapt on out to a muffler or chrome straight pipe.
Dave in Midland
12-07-2005 20:18:49
I tried JB Weld on an 10 hp aluminum Tecumseh engine (twice) and it just burned out - evidently it can't handle that much heat.
Don-Wi
12-07-2005 19:52:29
Pipe threads are tapered. You should be able to run a tap a little bit deeper and clean it up some. A new muffler would probably help as well.
Donovan from Wisconsin
mowr
12-07-2005 19:48:52
I'm sure you're aware that that is a standard pipe thread. If you get (perhaps rent from a tool rental or supply store) that size pipe tap, you very possibly may be able to chase the threads back to original or at least close enough for a good fix. It has worked for me.
BushogPapa
12-07-2005 19:44:46
I rented a thread tap and ran it in and cut the threads a little deeper in the port..can you do that..?? Or, you can drill and tap 2 holes to bolt a muffler or plate to the block with a gasket... Kohlers used both types of mufflers...threaded and bolted...
Ron..
4010guy
12-07-2005 19:11:41
well back many years ago we had an old m with a bad man and we welded a steel pipe into the man with nickol rod.dont know if it was the rite thing to use but it did hold for years.just a thot! that was with a ark welder ok
